Skynet2 Публикувано 12 Септември, 2015 Доклад Публикувано 12 Септември, 2015 Здравеите имам Mikrotik RB1100AH 5 WAN 1 Lan PPPOE server се е ок но имам 1 проблем как данаправам FAILOVER ако испадне пример wan 2 автоматически да префрли на wan1?? еве export: /interface ethernet set [ find default-name=ether1 ] name=LAN set [ find default-name=ether2 ] name=optika set [ find default-name=ether6 ] name=wan1 set [ find default-name=ether7 ] name=wan2 set [ find default-name=ether8 ] name=wan3 set [ find default-name=ether9 ] name=wan4 set [ find default-name=ether5 ] name=wan5 /ip pool add name=adsl1 ranges=10.0.10.10-10.0.10.254 add name=adsl2 ranges=10.128.22.10-10.128.22.254 add name=adsl3 ranges=10.127.22.10-10.127.22.254 add name=adsl4 ranges=10.126.22.10-10.126.22.254 add name=adsl5 ranges=10.129.22.10-10.129.22.254 add name=vadsl1 ranges=10.130.22.10-10.130.22.254 add name=vadsl2 ranges=10.131.22.10-10.131.22.254 add name=vadsl3 ranges=10.132.22.10-10.132.22.254 add name=vadsl4 ranges=10.133.22.10-10.133.22.254 add name="neplateni smetki" ranges=10.135.22.10-10.135.22.254 /ip firewall mangle add action=change-ttl chain=prerouting disabled=yes new-ttl=set:1 protocol=icmp add action=mark-routing chain=prerouting new-routing-mark=adsl1 passthrough=no \ src-address=10.0.10.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl4 passthrough=no \ src-address=10.126.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl2 passthrough=no \ src-address=10.128.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl3 passthrough=no \ src-address=10.127.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl5 passthrough=no \ src-address=10.129.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl1 passthrough=no \ src-address=10.130.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl2 passthrough=no \ src-address=10.131.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl3 passthrough=no \ src-address=10.132.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl4 passthrough=no \ src-address=10.133.22.0/24 /ip firewall nat add action=masquerade chain=srcnat disabled=yes src-address=192.168.0.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.0.10.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.128.22.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.127.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.126.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.129.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.130.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.131.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.132.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.133.22.0/24 to-addresses=\ 0.0.0.0 /ip address add address=10.125.90.82/24 interface=wan5 network=10.125.90.0 add address=10.125.20.18/24 interface=wan1 network=10.125.20.0 add address=10.11.11.2/24 interface=vlan1 network=10.11.11.0 add address=10.100.0.1/24 interface=LAN network=10.100.0.0 add address=10.125.20.89/24 interface=wan4 network=10.125.20.0 add address=10.125.30.24/24 interface=wan3 network=10.125.30.0 add address=10.125.70.54/24 interface=wan2 network=10.125.70.0 add address=192.168.100.2/24 interface=optika network=192.168.100.0 /ip route add distance=1 gateway=10.125.20.1 routing-mark=adsl1 add distance=1 gateway=10.125.20.1 routing-mark=adsl4 add distance=1 gateway=10.125.70.1 routing-mark=adsl2 add distance=1 gateway=10.125.30.1 routing-mark=adsl3 add distance=1 gateway=10.125.90.1 routing-mark=adsl5 add distance=2 gateway=192.168.100.1 ppp profile set *0 dns-server=8.8.8.8 local-address=10.0.10.2 remote-address=adsl1 use-compression=no use-encryption=no add dns-server=8.8.8.8 local-address=10.0.10.2 name="adsl1 8500/1500" rate-limit=1500000/7750000 remote-address=adsl1 use-encryption=no add change-tcp-mss=no dns-server=8.8.8.8 local-address=10.128.22.2 name="adsl2 7500/1000" rate-limit=1500000/7750000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.127.22.2 name="adsl3 7500/1000" rate-limit=1500000/7750000 remote-address=adsl3 use-encryption=no add change-tcp-mss=yes dns-server=8.8.8.8 local-address=10.126.22.2 name="adsl4 8500/1500" rate-limit=1500000/7750000 remote-address=adsl4 use-encryption=no add dns-server=8.8.8.8 local-address=10.128.22.2 name="adsl2 2000/512" rate-limit=100000/1950000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.130.22.2 name="wadsl1 8900/1500" rate-limit=1502000/6650000 remote-address=vadsl1 use-encryption=no add dns-server=8.8.8.8 local-address=10.131.22.2 name="vadsl2 8700/1512" rate-limit=1512000/8700000 remote-address=vadsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.129.22.2 name="namalena brzina 700/512" rate-limit=120000/516000 remote-address=adsl5 use-encryption=no add dns-server=8.8.8.8 local-address=10.130.22.2 name="vadsl 1 4200/1000" rate-limit=1000000/4250000 remote-address=vadsl1 use-encryption=no add dns-server=8.8.8.8 local-address=10.126.22.2 name="za firmi" rate-limit=4512000/6000000 remote-address=adsl4 use-encryption=no add local-address=10.139.22.2 name="neplateni smetki" rate-limit=20/60 remote-address="neplateni smetki" use-encryption=no add dns-server=8.8.8.8,62.162.32.5 local-address=10.128.22.2 name="adsl2 5000/1500" rate-limit=1500000/5900000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.127.22.2 name="adsl3 8000/1000" rate-limit=1500000/7700000 remote-address=adsl3 use-encryption=no add dns-server=8.8.8.8,80.77.144.10 local-address=10.130.22.2 name="na 200 denari" rate-limit=512000/4800000 remote-address=adsl3 add dns-server=8.8.8.8 local-address=10.129.22.2 name="adsl5 8500/1500" rate-limit=1500000/7750000 remote-address=adsl5 use-encryption=no add dns-server=8.8.8.8 local-address=10.129.22.2 name="adsl5 9000/1500" rate-limit=1500000/10500000 remote-address=adsl5 use-encryption=no set *FFFFFFFE use-encryption=no /interface pptp-server server set max-mru=1460 max-mtu=1460
0 Администратор JohnTRIVOLTA Отговорено 14 Септември, 2015 Администратор Доклад Отговорено 14 Септември, 2015 PCC
0 Skynet2 Отговорено 19 Септември, 2015 Автор Доклад Отговорено 19 Септември, 2015 Во овој мој случај како да го подесам този настројки во МТ?
0 Администратор JohnTRIVOLTA Отговорено 20 Септември, 2015 Администратор Доклад Отговорено 20 Септември, 2015 (Редактирано) На пътищата си сложи и chack gateway - ping за всеки gateway , тоест ако няма пинг пътя става неактивен ! А иначе с distance може да зададеш приоритет /предпочитание/ колкото е по-малка цифрата /числото/ толкова по-голям приоритет ще има пътя ! Редактирано 20 Септември, 2015 от JohnTRIVOLTA
Skynet2
еве export:
/interface ethernet set [ find default-name=ether1 ] name=LAN set [ find default-name=ether2 ] name=optika set [ find default-name=ether6 ] name=wan1 set [ find default-name=ether7 ] name=wan2 set [ find default-name=ether8 ] name=wan3 set [ find default-name=ether9 ] name=wan4 set [ find default-name=ether5 ] name=wan5 /ip pool add name=adsl1 ranges=10.0.10.10-10.0.10.254 add name=adsl2 ranges=10.128.22.10-10.128.22.254 add name=adsl3 ranges=10.127.22.10-10.127.22.254 add name=adsl4 ranges=10.126.22.10-10.126.22.254 add name=adsl5 ranges=10.129.22.10-10.129.22.254 add name=vadsl1 ranges=10.130.22.10-10.130.22.254 add name=vadsl2 ranges=10.131.22.10-10.131.22.254 add name=vadsl3 ranges=10.132.22.10-10.132.22.254 add name=vadsl4 ranges=10.133.22.10-10.133.22.254 add name="neplateni smetki" ranges=10.135.22.10-10.135.22.254 /ip firewall mangle add action=change-ttl chain=prerouting disabled=yes new-ttl=set:1 protocol=icmp add action=mark-routing chain=prerouting new-routing-mark=adsl1 passthrough=no \ src-address=10.0.10.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl4 passthrough=no \ src-address=10.126.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl2 passthrough=no \ src-address=10.128.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl3 passthrough=no \ src-address=10.127.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=adsl5 passthrough=no \ src-address=10.129.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl1 passthrough=no \ src-address=10.130.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl2 passthrough=no \ src-address=10.131.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl3 passthrough=no \ src-address=10.132.22.0/24 add action=mark-routing chain=prerouting new-routing-mark=vadsl4 passthrough=no \ src-address=10.133.22.0/24 /ip firewall nat add action=masquerade chain=srcnat disabled=yes src-address=192.168.0.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.0.10.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.128.22.0/24 to-addresses=0.0.0.0 add action=masquerade chain=srcnat src-address=10.127.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.126.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.129.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.130.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.131.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.132.22.0/24 to-addresses=\ 0.0.0.0 add action=masquerade chain=srcnat src-address=10.133.22.0/24 to-addresses=\ 0.0.0.0 /ip address add address=10.125.90.82/24 interface=wan5 network=10.125.90.0 add address=10.125.20.18/24 interface=wan1 network=10.125.20.0 add address=10.11.11.2/24 interface=vlan1 network=10.11.11.0 add address=10.100.0.1/24 interface=LAN network=10.100.0.0 add address=10.125.20.89/24 interface=wan4 network=10.125.20.0 add address=10.125.30.24/24 interface=wan3 network=10.125.30.0 add address=10.125.70.54/24 interface=wan2 network=10.125.70.0 add address=192.168.100.2/24 interface=optika network=192.168.100.0 /ip route add distance=1 gateway=10.125.20.1 routing-mark=adsl1 add distance=1 gateway=10.125.20.1 routing-mark=adsl4 add distance=1 gateway=10.125.70.1 routing-mark=adsl2 add distance=1 gateway=10.125.30.1 routing-mark=adsl3 add distance=1 gateway=10.125.90.1 routing-mark=adsl5 add distance=2 gateway=192.168.100.1 ppp profile set *0 dns-server=8.8.8.8 local-address=10.0.10.2 remote-address=adsl1 use-compression=no use-encryption=no add dns-server=8.8.8.8 local-address=10.0.10.2 name="adsl1 8500/1500" rate-limit=1500000/7750000 remote-address=adsl1 use-encryption=no add change-tcp-mss=no dns-server=8.8.8.8 local-address=10.128.22.2 name="adsl2 7500/1000" rate-limit=1500000/7750000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.127.22.2 name="adsl3 7500/1000" rate-limit=1500000/7750000 remote-address=adsl3 use-encryption=no add change-tcp-mss=yes dns-server=8.8.8.8 local-address=10.126.22.2 name="adsl4 8500/1500" rate-limit=1500000/7750000 remote-address=adsl4 use-encryption=no add dns-server=8.8.8.8 local-address=10.128.22.2 name="adsl2 2000/512" rate-limit=100000/1950000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.130.22.2 name="wadsl1 8900/1500" rate-limit=1502000/6650000 remote-address=vadsl1 use-encryption=no add dns-server=8.8.8.8 local-address=10.131.22.2 name="vadsl2 8700/1512" rate-limit=1512000/8700000 remote-address=vadsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.129.22.2 name="namalena brzina 700/512" rate-limit=120000/516000 remote-address=adsl5 use-encryption=no add dns-server=8.8.8.8 local-address=10.130.22.2 name="vadsl 1 4200/1000" rate-limit=1000000/4250000 remote-address=vadsl1 use-encryption=no add dns-server=8.8.8.8 local-address=10.126.22.2 name="za firmi" rate-limit=4512000/6000000 remote-address=adsl4 use-encryption=no add local-address=10.139.22.2 name="neplateni smetki" rate-limit=20/60 remote-address="neplateni smetki" use-encryption=no add dns-server=8.8.8.8,62.162.32.5 local-address=10.128.22.2 name="adsl2 5000/1500" rate-limit=1500000/5900000 remote-address=adsl2 use-encryption=no add dns-server=8.8.8.8 local-address=10.127.22.2 name="adsl3 8000/1000" rate-limit=1500000/7700000 remote-address=adsl3 use-encryption=no add dns-server=8.8.8.8,80.77.144.10 local-address=10.130.22.2 name="na 200 denari" rate-limit=512000/4800000 remote-address=adsl3 add dns-server=8.8.8.8 local-address=10.129.22.2 name="adsl5 8500/1500" rate-limit=1500000/7750000 remote-address=adsl5 use-encryption=no add dns-server=8.8.8.8 local-address=10.129.22.2 name="adsl5 9000/1500" rate-limit=1500000/10500000 remote-address=adsl5 use-encryption=no set *FFFFFFFE use-encryption=no /interface pptp-server server set max-mru=1460 max-mtu=14603 отговори на този въпрос
